To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Relay Wiring
zeroarcticzeroarctic Member Posts: 1
I recently had a radiant zone added to my existing baseboard system. The manifold came with a i-Link SP-81. The existing aquastat/controller is a Honeywell 8148a with Taco Zone Sentry valves. . The tech plans to wire the tt from the i-link to the tt on the 8148a . Is this proper as the tt from the zone valves is already connected?
  • Tim McElwainTim McElwain Member Posts: 3,779
    Is the radiant zone
    on one of the Taco Zone Valves? Typically the zone valves are powered by the sensing control and the end switch on the zone valve brings on the relay which fires the burner and brings on the circulator. I am not completely aware of what the i -link SP-81 does?
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
