Please help aquastat
Dac7660
Member Posts: 1
Does anybody know of a Honeywell L8148a is the same as a
L8148J
L8148J
difference
Kinda the same in most common systems ... The J can also be used on a 24V and millivolt gas valve and a low limit can also be added ....I have enough experience to know , that I dont know it all0 -
No it is not the
L8148A is a 120 volt burner circuit. The L8148J is a universal replacement relay for 24 volts of millivolts(Powerpile Self Generating). You have to replace an "A" with an "A".0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
