fuel cell
RJ_4
Member Posts: 484
A friend called me from another state about a major hvac upgrade they are looking at doing to there church. One person at the church wanted to look into replacing the boiler and emergency generator with a fuel cell ? any input on this would be great. don't know any equip details at this time.
thanks Rick
thanks Rick
Numbers:
When they crunch the numbers, they'll be putting in a new boiler.0 -
One of the minor beauties
about fuel cells is that they don't produce much heat. So the question might be asked, how are they proposing to supply heat to their HVAC? Or is this in some southern clime?
There is a downside... a, those puppies don't come cheap and b, they do need fuel... and unless they are hydrogen cells, they don't do anything different environmentally than a good clean burning gas boiler or oil boiler (depending on the fuel).
If they want to go off grid, they'd be much better off (unless their heat loads are very small) to go with a natural gas (if available) or diesel co-gen system.
If their budget is anything like most churches, they'll be putting in a boiler, as Icesailor says!
But there's one in every crowd, I guess.Br. Jamie, osb
fuel cell
Thanks all . RickThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
