intalling heat pump in place of central AC and making 11 year old oil fire furnace my back-up
oakland
Member Posts: 23
I want to convert from oil fired hot air Lennox elite series furnace to a two stage variable speed Goodman heat pump and make my oil furnace the back-up. The Goodman heat pump will go in place of my 5 ton central AC unit and act as a heat and AC source. The furnace blower handled the AC and furnace hot air. I believe i can change the blower from single stage to variable speed with a retrofit motor. Do i have to change the old control board on the furnace because i am adding a second heat source and making the oil the back-up and trying to mesh two different companies and sharing the blower and making the blower variable speed?
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
