To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
tenant heat metering
rjncontrjncont Posts: 1Member
what is an accurate means to meter tenant heating from a central heat source (oil boiler)? all units are zoned individually
  • RichRich Posts: 1,793Member ✭✭✭✭
    edited March 2014
    Taco
    Iworx system can be part of the system also because nobody will just take your math at face value .  You will also require a KNOWN Delta T . There are a few choices of circulator that will closely control Delta T . Taco VDT and Bumble Bee , also Wilo Stratos with IR option .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    Langans Plumbing & Heating LLC 732-751-1560
    Serving most of New Jersey , Eastern Pa .
    Consultation , Design & Installation
    Rich McGrath 732-581-3833
  • Big EdBig Ed Posts: 757Member ✭✭
    Tenants
    We all know the best option is a separate boiler and oil tank
    I have enough experience to know , that I dont know it all
  • maine rickmaine rick Posts: 107Member
    control
    we use Honeywell AQ control with communicating thermostats. you can set the max temp and check the amount of hours each zone runs. also is outdoor reset ready.
    JPG
    JPG
    0B
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
