Heating-Cooling Loss and Gain
TonyS
Member Posts: 849
How many of you live in areas where a heat loss is required for a permit and how is that implemented? I would like to have it in our area but need a few ideas how to bring it before the board?
A very good idea
Could it be done by a separate person from the installer?
Obviously a radiator survey should be done for steam systems.--NBC0 -
I believe the RPA
is currently working on this, in the form of a radiant heating and solar code.0 -
Heat loss/gain
In my area we are rquire to perform manual J,Manual D and a manual S before a permit is ever issue.We are also require to do a duct leakage test or a visual inspection by the inspector on all duct joint.Guess which one they rather have.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
