Janitrol Automatic pilot
DPeak
Member Posts: 3
in Gas Heating
Our very old hot water system has a pilot control made by Janitrol/Surface Combustion. It sends an electrical signal confirming the pilot is lit to a controller that opens the gas valve. The type designation is X O. It has apparently died, as bypassing it allows the boiler to fire. See picture attached.
Anybody know if there is a modern replacement part available? Or if there are any originals floating around?
<a href="http://www.heatinghelp.com/images/posts/23091/resize_2014-02-24_Janitrol_Pilot.jpg"></a>
Does it
Have a thermocouple attached to it? If it does you can still get a BASO control.0 -
That pilot is obsolete and
no longer available. You would have to d a complete changeover which is not cheap and requires someone with experience at doing such things. Sound like it is time to replace the old boiler.0 -
Thanks, I appreciate the input. I assumed that would be the case, so we are already moving that direction. Sure hate to see the old boiler go, it had a good long run.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
