To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Bell and Gossett 100 mystery sounds
Hello there, Long time lurker here seeking your expert advice. I had some awful metal scraping sounds coming from my B&G 100 series pump. It's a hot water baseboard system. I checked for the obvious and found a mangled coupler inside. After carefully replacing the coupler and very lightly oiling the 2 motor tubes, and heavily oiling the bearing assembly, I turned the pump back on.
Now I'm getting a very different grinding sound. Not as loud but still not right. It sounds like there is a piece of metal clanging around in there near the bearing assembly or impeller. I know I pulled the entire coupling out, so it can't be that.
Am I missing something here fellas?
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
