National 'Aero" Cast Iron Convectors
heatseeker
Member Posts: 1
what convector can you use to replace "National Aero Cast Iron Convector" without having to replace the existing cabinets which will have same heating surface output ?
see attached photo
see attached photo
Convector conversions:
If it's hot water, probably any amount of coil convectors that you can stack in there to equal what you already have.0
- 86.3K THE MAIN WALL
- 50 Biomass
- 419 Carbon Monoxide Awareness
- 91 Chimneys & Flues
- 5.4K Gas Heating
- 93 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 59 Pipe Deterioration
- 920 Plumbing
- 6.1K Radiant Heating
- 374 Solar
- 15K Strictly Steam
- 50 Water Quality
- 40 Industry Classes
