piping down right ?help
joewolf
Member Posts: 19
can anyone tell me if this piping is right? the broliler is gsa 300 low pressure steam ,one pipe sistem
PipingN
No, not even close. At least it's not copper.0 -
piping down right ? help
thanks jstar , can you please tell me what kind of problem this wrong piping would cause? and would you draw a skit of a right piping.thanks in advance .JOE0 -
hello, is there a device that could detect steam leaks .thanks in advance .JOE0
I use an ear, an eye, and sometimes a mirror. I've heard of people throwing something into the water to make it smell so you could use your nose.joewolf said:hello, is there a device that could detect steam leaks .thanks in advance .JOE
Peppermint oil and (apparently) black pepper will work.0
Here's the Williamson manual for these boilers. The piping diagram is on page 11. It only shows one riser to the header, but the steam takeoff point is between the riser and the equalizer:
http://www.williamson-thermoflo.com/en/assets/pdf/w-gsa_manual.pdfAll Steamed Up, Inc.
Consulting0 -
thanks to all guys0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
