Laars Endurance Boiler L.O. code
Shell4k
Member Posts: 1
Hi all,
My Laars Endurance boiler (or water heater, not sure about the right terminology) is stuck on L.O. My super tells me that means it's on Lock Out. This has happened a number of times before, and I believe as a result he once replaced the ignitor.
I have attempted powering the unit on and off, and when I power it back on it goes to Lockout immediately.
We recently had a power outage in my area, so I'm not sure if that could be part of the problem...my super said it is but that sounds too convenient.
I'm tired of hearing my super's excuses, and would like to possess some knowledge so I can help myself now or in the future.
I appreciate any help.
L.O
LO does mean Lock Out. It comes up from a variety of things. If it comes up immediately after hitting reset I would say it's more than likely a control or wiring problem. You can do an internet search for Laars Endurance Manual and walk thru the steps to find the fault.Tom
Montpelier Vt0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
