Riello 4.0
taz
Member Posts: 13
Burner runs shuts off on temp. Have to hit reset and bleed line for it to fire again. Changed filter ,tighten all fittings. What's next?
find vacuum leak
Do you have a buried tank? There is air leaking into your oil line from somewhere. Time to pull out the vacuum gauge and start looking.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
