Gateway + Aerco + Caleffi = nice job.
JohnNY
Member Posts: 3,231
Here's a nice job in progress.
Go ahead, haters.
Go ahead, haters.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
No Pictures
The pic did not come through."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I got the pictures
Good looking stuff. What's with the haters thing?0 -
The only thing I hate...
Is that I'll never get my solder joints to look that sweet. There's a YouTube video I'd love to see.
I actually misread the title and thought it said 'propress' instead of 'progress’
Top quality work, John.There was an error rendering this rich post.
well
One of the ball valve levers are not level and those red pumps don't have the best wire to water transfer, John.0 -
Choking you pumps
I would make the recommendation to install the mixing device in the diverting position and not the mixing arraignment. The mixing setup creates a restriction on the inlet of the pump and is well known to disrupt the pump performance/ability to pass air.0 -
Specific?
Kevin,
Could you be more specific?
If the circ is moved outside the loop, there is no circulation through the loop when the valve is diverting. This won't work work in a heating loop. Maybe I am misunderstanding your meaning.
John,
Nice looking job. Do you have final pics?
Albert Einstein0 -
...0 -
No idea...
...what this means.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
