Rinnai Continuum 2520 help
Jackster8
Member Posts: 1
Hello,
I have an issue that is stumping my installer and level 2/3 tech. I also contacted Rinnai.
I have this unit for about 7 years and have had 5.5 great years with it. The last 1.5 years though I have had a decrease in my water temp to 103-5 degrees at best (i measured with a thermoter). sometimes it pulses to colder than that. I have very sporatic moments of normal 120 degrees - once every couple of weeks perhaps.
I have hard water and iron riich. I have a softener and Acid nuetralizer on the well supply to my home. I do get some rust (iron) sediment build up on occasion. I've flushed the system, cleaned the barrel screen on the water inlet and had two service techs in to take a look at it. #1 the installer and #2 the level 2/3 tech. The second of the two recent suggested it may be my flow sensors. I managed to find the one on the top right and that looks normal.
Anyone have any suggestions? My level 2/3 guy is very busy and not anywhere near my location so it is hard for him to get to us.
Jack
Jack
Code
What code are you getting, does the thermistors need to be cleaned or swapped out. Do you have a gas meter to check gas pressure. What did the tech say?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
