Riello Burner making noise
RRyan83
Member Posts: 1
in Oil Heating
Hello, I have a Riello F40 Oil Burner and it is making a intermittent noise. After inspection with a friend we 'think' that the coupling is bad. Seems pretty easy to fix but can't find a place inside the United States that has the part. I'm not even sure what part I need. Any help with this would be greatly appreciated....Thanks, Rob
Whatchya need....
Is to call a qualified tech. Could be something completely different. A Riello burner needs the right person and it will run great. Or the wrong person and it won't. The adjustments between the 2 are very minor. You need the right training, skill, and experience or you will waste time and become very aggravated.
Riello pumps don't have a coupling, which is why you cant find one. But the part you do need is readily available.There was an error rendering this rich post.
one thing as with all oil burners
with removable covers is that you can remove the cover take it outside and clean it periodically.
like us it needs to be able to breath , it has a bit of a dust collector in the box and it is black . if it looks brown or any other colour it is probably going to be able to breath better just by cleaning it ....
give that a try ...
it cannot hurt it to do that much ...
Weezbo.0 -
riello pump couplers
Riellos do have pump couplings. But they are one piece and very compact. I have never had to change one yet. If you are hearing a screeching type of noise the motor may be on its way out.There was an error rendering this rich post.
Yes Earl.....
Was just making a point that its called something else, which is why he couldn't find one and a qualified tech would know thatThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
