Honeywell WIFI thermostat RTH9580WF
Ross13
Member Posts: 4
in Oil Heating
I have a 2 zone oil heat system. I currently have LuxPro thermostats. The three wires coming out of the wall are the following:
RED - connected to RH
WHITE - connected to W
GREEN - NOT USED (not shown in picture)
BLACK - Jumped between RH & RC
The new Honeywell WIFI thermostat states you need a "C" wire for power. I went down to the Burhnam furnace to check Honeywell board and the GREEN wire is not connected to anything. I also do not see anywhere on the board a "C" to connect to?
Any suggestions. Attached are 3 pictures. In order, Honeywell control board @ the furnace, current LuxPro t-stat, & the new Honeywell t-stat.
Thermostat
You can check out the You Tube video on this thermostat installation. The thermostat needs the C wire to power thermostat. It has to have power other than batteries the old thermostat had. I would say you can't use this thermostat with the L8124 control you have.0 -
WiFi
Add a switching relay with a Common terminal We use the Honeywell R8845U.0 -
R8845U
I see where you could use this control as long as you have 3 wires at the thermostat.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
