To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
How clean up penetrating oil in pipes?
brucebruce Member Posts: 221
To remove old 4 bolt well seal sprayed Wd on the bolts. Now it can be tasted in the sink.
How to get it cleaned up?
  • icesailoricesailor Member Posts: 7,265
    Aromatic Odors:
    The solution to pollution is dilution. Run the water for a very long time at an outside faucet or at the well tank. Like for HOURS.
    You DID use Never-seize on the bolts of the cap after you put it back together so the next person to come along doesn't have the same problem as you?
    The next person could be you again or someone like me who will have no end of names to call the person who installed a nut and bolt fastener without using any form of thread lubricant.
    How do you get insects (like ants) out of a well when they go up the electrical conduit and make a nest on top of the wires and pull rope. And when they die, the colony pushes them out of the nest and the bodies come out of the tap in the house? (Same answer to your problem)
    Pull the pump, have the driller or someone stick a piece of pipe connected to a large air compressor hose down to the bottom of the well and re-develop it.
    That's what I did .
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
