Oversized boiler
TonyS
Member Posts: 849
I went to look at a job that was put in a few years ago, its got everything, cast rads in the old section, baseboard fin and radiant in the new. Complete disaster!
The boiler was installed a few years ago also, Burnham cast iron 170k ,its about a 100k over sized. Question is ...How do you guys feel about removing burners to down fire this beast. PROS...CONS AND TECHNIQUES ?
I Wouldn't Do It
Tony,
I wouldn't do it under any circumstance. If you do, you own it and all the ramifications that come with it. It's illegal to modify the gas train in a manner not approved by the manufacturer and AGA. I'm sure Tim can give better specifics.
I'd look at a buffer tank or a properly sized boiler.Bob Boan
Not a good idea for a couple of reasons
1. The overall efficiency will be affected as you still have to heat all the sections
2. Safe ignition can also be a problem depending on what burners are blocked off.
3. It could affect the warranty on the boiler if that is still a factor depending on age
4. Manufacturers of equipment will not authorize such a move.
You can by changing all the orifices to smaller size or adjusting pressure typically reduce input about 10% which is not the best but better than blocking off burners.
In all cases I would do a before and after combustion analysis.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
