Help with Buderus Logamatic 2107
gleinz
Member Posts: 1
in Oil Heating
Hello,
I'm having 2 issues with my Buderus Logamatic 2107:
1) The outdoor temperature sensor failed... did some research, and I removed the thermistor to have it default to 14F (-10C) and have ordered a replacement. My question is, does anyone know what type of thermistor is used in the sensor? I've tried to look a few up and based on the Temperature vs. Resistance chart in the Buderus documentation, I think something like this might work: <a href="http://www.jameco.com/Jameco/Products/ProdDS/207037.pdf">http://www.jameco.com/Jameco/Products/ProdDS/207037.pdf</a>
2) When I check the "Hours Run" function, it always reads zero... does anyone know how to fix this?
Thank you!
Thank you!
I would just replace the factory sensor with one from Buderus, it really makes the most sense.
To get the hours run function to work requires a small amount of rewiring at the control.
http://www.buderus.us/files/201006231702550.6720618142_2107_Installation_Service.pdf
page 63 terminal 8 powers the hours run timer0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
