Pipe Killers
Paul48
Member Posts: 4,469
in Gas Heating
A while back I posted about my deteriorating smoke pipe.I was trying to figure out how my gas conversion could have been causing this problem.As it turns out, 2 winters ago, the oil company I had my service contract with, replaced my aquastat. I didn't check the setting until this morning, and it seems he set the hi-limit to 170 and the lo-limit to 130 with a 10 deg differential. So, in this old gravity conversion, I was circulating water down to 120 degrees for a good long time.Ughhh.....Mo' Money..Mo' Money...Mo' Money
Bypass
Sounds like you don’t have a boiler bypass…That goes back to original installer…if not installed…If the boiler is older it would be a waste of time to install one now….Damaged done….Boiler and venting system0 -
No Bypass
Although not the best, the triple aquastat(set correctly) worked well for this system.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
