any one recognize this trap
mshep
Member Posts: 4
Anyone know what model this trap is? Cover shows Illinois engineering co. , no model # or other info on body and internal removed at some point. Hoping to find replacement inserts rather than replacing all the traps
It's the Illinois 1T
which is called an Outboard trap. Marsh and Sterling also made outboard traps. I'm assuming it has the usual 1/2" pipe connections.
Tunstall and Barnes & Jones both make kits for these, but you will probably have to get a new cap as well as the capsule or cage unit for each trap. Still, it's a lot less trouble to rebuild rather than completely replace these traps.All Steamed Up, Inc.
Consulting0 -
bigger than 1T?
Life would be so much easier if they just put model #s on them. Picked up replacement cover for a 1T and the cover diameter is too small. Posted pictures of the difference. I see Illinois also lists an outboard 1/2" trap as a 2T. Is it possible it is the same trap with bigger diameter cover. Reached out to B and J but haven't heard back0 -
size difference
pics of trap cover vs 1T replacement cover0 -
That's a new one on me
measure the diameter of your original cap so they can cross-reference it.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
