Effects of system vacuum on gauges, and vaporstats?
nicholas bonham-carter
Member Posts: 8,576
What stages are the people of the vacuum in at the moment?
Has there been any damage to gauges, or vaporstats?--NBC
no effect
I have run as high as a 10" if vacuum. It has had no effect on vaporstat or gauges.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
