Condensate Hot-Water Heating FAQ
wdaryl
Member Posts: 1
In this FAQ section several diagrams indicate a "flow control valve". Are these standard swing check valves or some other style of valve.
Flow Control Valve
Spring or swing check valves will work as will flow control valves like this one:
http://www.pexsupply.com/Taco-218-3-3-4-IPS-Universal-CI-Taco-Flo-Chek-1988000-p?gclid=CJDMlczW0bsCFUZqfgodNAIAKA8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
