Molex plug
JStar
Member Posts: 2,752
in Oil Heating
Anybody have a part number for the molex connectors on the burner primary? Our usual supply house didn't have an answer. We always receive the boiler side of the plug in our wiring harnesses, but never have the other half.
Molex
If you look carefully there should be a number molded into the connector. Mouser.com stocks a lot of molex parts so searching there may let you determine the part number of the mate. You usually have to buy the pins separately unless it mounts to a circuit card.
3PSI gauge0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
