To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
trying to combine fireplace with heat pump
hello,
this is my first time on this site. so i hope that i'm posted to the right place.  i'm in a house in Pennsylvania that has 20' vaulted ceilings.  it has become a nightmare to heat.  the existing system in an electric and oil heat pump.  it cost a fortune to heat this house, so we've been using the wood stove in the basement, which almost does the job.  how ever this house does have an interesting feature.  in the living room with the high ceiling, is a fire place.  the rack that holds the logs in the fireplace is actually water pipes.  the inlets for these water pipes happen to reside just a few feet from the heat pump.
what i would like to do is attach a small water tank to one of the inlets and have the other go to a radiator in duct work to the heat pump, then back to the tank.
i obviously have many questions on how to do this.
1.  would i need a circulating pump?
2. what size tank (if any) should i use?
3. do i place the radiator before of after the heat pump?
4. where can i find suck a radiator?
5. is there a brand/model/style i should be looking for?
any help would be nice
thank you
  • TonySTonyS Member Posts: 849
    Dont do that
    you would be building a bomb. Second, you would be losing heat faster than your making it. Fireplaces typically use 500 cfm of indoor air. The only heat you get from a fireplace is radiant when standing in front of it.
    They do make fireplace inserts that have efficiency approaching 80%. Forget about making hot water with it. That would be your best bet.
    Google...quadrafire or Jotul
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
