Boiler Nozzle conversion - Help!
HVACNJ
Member Posts: 2
Oil / Gas Nozzle conversion - HELP!
Looking for some advice here -
My current setup is a weil Mclain 68 Oil - Steam boiler (model P-368-S)
with a AFG (MP1192) oil burner. The unit is approx 12 yrs old and have
had no issues so far - knock on wood.
As I said, I currently have oil - there is gas in the street and a quick
call to the township and gas company confirmed all it would cost me to
tie in would be $125 for the permit and of course a heating system that
utilizes Gas. The township has approved paving the street in the spring
time (5 mths from now) after which time they will not allow you to open
the street for 5 years (unless there is an emergency). The catch to this
whole thing is that I am planing on putting the house on the market in
the spring....
So i'm looking for advice on whether its
A) feasible to swap out the nozzle, sacrifice the efficiency, and just get the gas to the house
B) swap out the furnace and install a gas (prob my last choice)
C) Let it ride how it is and roll the dice.
I am worried if I don't end up selling the house and something does
happen to the boiler, since I cannot open the street - I will have no
option but to get another oil unit.
I am on the fence with what makes the most sense - I dont want to be paying for a new heating system for someone else to enjoy.
the spring....
Oil
See my response in the Oil Forum.0 -
you can't
You can't just swap out the nozzle.
Ok to clarify... a furnace is forced hot air... a boiler contains water and can be hot water or steam. It is confusing when you use both terms together, what do you have? and if a boiler is it hot water filled or steam?
You will most likely be able to buy a gas conversion burner, which will bolt up to your existing boiler/furnace, but they ain't cheap, and I wouldn't recommend it on an older unit.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
