Ecuacool - Jstar - Water Hammer, Wet Steam, Etc
ALIGA
Member Posts: 194
With the start of the new heating season, every morning woke up to 5 minute banging of pipes. No alarm clock needed in the morning, woke me up every single day.
Contacted Jstar, he came onsite, analyzed the problem, and gave me a quote, and a day he can begin the job on the spot. I gave him the ok to proceed.
A week later he came and completed the job, pics attached below. I was not home when the job was completed. But my wife sang nothing but praises for Jstar.
Basically the problem lied at the end of the main, did not have proper slope for the supply and return. Jstar eliminated the tee, replaced it with an elbow, relocated the vents, and pitched it properly.
After he left there was still some banging in the pipes, roughly a week later, the banging is GONE!
I also had a problem with disappearing water. After the pipe work, and me skimming the system a few times, the water stays put.
I highly recommend Jstar, he might be based out in NJ, but us NYers have someone to count on. Thank you again Joe!
Steam
Always a pleasure to help a fellow Wallie.
Was there still a noise coming from the bedroom radiator?0 -
No sounds at all
After replacing the radiator valve on the third floor bedroom right above the one in question, no sounds.
As you mentioned on another post, can't blame the boiler, have to take a look at entire system.0 -
Joe
Joe is the only one in New Jersey that I would want working on my steam system. When he works on a system you know its going to come out right. If there were more like him we would have far less steam to hot air conversions.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I wish
I wish he worked in Michigan!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
