Thermostat
Andrew boiler
Member Posts: 44
Hi I keep my thermistor at 68 and feels like more 65 I have my own zone for my master bedroom.
Any idea what I should set it to
If chilly, set a higher temperature
Have you got an accurate digital thermometer to show the exact temperature?
Until you get one, then raise the setting by 1 degree each time until you are comfortable.
Check any windows in the room for leakage, so there are no drafts of cold air coming into the room.
Get a nice Duvet from Iceland mills to keep you warm until you find the right temperature.--NBC0 -
Turn it up!!!
It is obvious from your frequent posts on this issue the you prefer to have the house warm. I think that rather than saying "it feels like 65", you should simply raise the thermostat until you are comfortable. Problem solved! Who cares what the t-stat says?
Albert Einstein0 -
What
They said.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
