To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
heat ducts leak water. Have a boiler system
I recently started having a problem with my boiler causing my heating ducts to leak water from the vent.  Can someone tell me what would cause this.  The air handlers have been off lately because the temp in this building gets really hot.
Need help
Mac
  • nicholas bonham-carternicholas bonham-carter Member Posts: 6,181 ✭✭✭✭
    Leaky ducts
    I presume you have coils in the ducts fed from a boiler for heat. What sort of system is it-hot water or steam?
    There must be a leak in the coil or it's connections. Can you see anything by removing the grill, or some other access panel in the ductwork?--NBC
  • WeezboWeezbo Member Posts: 6,232 ✭✭✭
    isolation ....
    of system fault would be the best bet.
    if you have multiple air handlers with individual coils , water leaking out of a specific 'Vent" i'd likely isolate that zone and pressure test it , use the Go Pro ultrasound to pin point the leak. gate that unit off with a bypass ahead of the gates and turn the system back on . and check what if any other damage may have occurred .
    if there is one big air handler , then the coil /s may have one leak . that's it.
    hope that helps
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
