blower assembly
Paul S_3
Member Posts: 1,261
Doing job tomorrow, replacing blower assy. which includes replacing dual blower wheels ,shaft, brackets which hold bearings ...posted pic below of bearing ...i believe they are sleeve bearings correct me if im wrong...wanted to know if anyone has any tips on a job like this ...its a split 20 ton carrier system...thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
A few things
depending, you might be in/out in a hour or maybe five. 2x4 ,4x4 ,sawzall, files, hammers, ,punches, sand cloth , rust bust , autoball joint forkS, black pipe T - able to slide over the shaft, blk pipe nipples - longer than shaft to bearing, rags , BIG screwdrivers, pully puller's, pipe wrenches, grease gun, oiler ,regular tool box w/ allen wrench's both metric and regular, etc.0 -
bearings
ball bearing and set collar start by checking new parts make sure shaft is straight and there are keyways or flat sots in shaft. Sand and put rust dissolver on shaft by bearings, cut shaft and remove old wheels, install new wheels , slide shaft through wheels dont forget set collars which I like on inside of bearings , you can move shaft back and forth to install bearings, bearings are removed and instlled in bracket by turning 90 degrees, tighten blower wheels on shaft, reinstall blower pulleyThere was an error rendering this rich post.
thanks
Thanks guys for responses....David do you know name of that book Carrier makes? Thanks Paul SASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
blower assembly
Forgot about AntiSieze.How long did it take, how many techs, shaft size , bearing size? I KindaSorta like doing a job like that !0 -
CV joint
Some of the large carriers I've done have a CV joint between two shafts. Your idea of just replacing the whole thing (shaft, bearings, blower wheels, sheave, is definitley the way to go. You wont need alot of that other stuff seeing your going to toss all but the basket housings. Plan on a day doing it. Some of the carrier shafts go large in the middle but are hollow. Take off the top and take the baskets and all out in one piece, and work on the ground with your Saw-Zall and screw gun. On the new shaft , the cosmoline can be removed with WD-40 and some rags. Have new keys for the shaft also. a good staight edge to align the pulley and sheave. Amp the motor when done to make sure your under the nameplate amp draw on the motor, If not, adjust (open/close) the sheave till you are. Use Never Seize on the shaft, especially if your the one to service this equipment in the future.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
