Burnham Part/Manual V15 at
PABill
Member Posts: 1
I'm trying to locate a Canopy Assy for an old Burnham....the org is rusted thru.....rest of the boiler is in good shape. Burnham v-15 aT.......flue comes out the top.
Part number?????
Part number?????
Part
Did you call Burnham ? In the past I have had a local sheet metal shop make parts for me. If enough of your hood is left some one should be able be able to use dimension to fab a new one.
Is the boiler leaking ? or was this because of a lack of maintenance ?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
