To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
two pipe
Paul SPaul S Member Posts: 1,203
Hey everyone just came from call where another company installed a hot water boiler....the left side of home heats fine but the whole right side does not....its a copper based two pipe system....it tee's to both sides of home in the pic I posted....I bleed the and no air comes out...so I believe its a flow problem....previously the home had be vacant for one year with the system drained....could these connectors be clogged? Thanks Paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
[email protected]
ASMHVACNYC.COM
  • Paul SPaul S Member Posts: 1,203
    pics
    More pics
    347-692-4777
    [email protected]
    ASMHVACNYC.COM
  • Jamie HallJamie Hall Member Posts: 6,047
    Does the feed line
    to the right side get hot at all, or even warm, for any significant distance beyond the T?
    There could be a blockage, of course, although it isn't a bit common to have copper pipe in a closed system block up completely.  On the other hand, it wouldn't take that much resistance to flow on the right side to divert almost all of the flow to the left side -- but never all of it (which is why the first question.
    On the other hand, I see no way at all to balance the two side of the system in the pictures, leading me to wonder if there might not be a valve or two hiding somewhere which got shut off...
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
