To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Thermostat
Hi I am having problems with my Honey well PRO Non-Programmable Digital Thermostat (1 Heat don't know when I will need to get new. Bat tiers I think it's hard wire can any one help me
  • Jamie HallJamie Hall Member Posts: 6,065
    Kinda tough to do
    when you give no indication at all as to what your problem is.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • SWEISWEI Member Posts: 7,356
    This is the 12th thread you've started in one week
    about your thermostat.  WTF?
  • BobCBobC Member Posts: 4,247
    Complicated
    Two wires AND a knob, no end of mischief can come from something like that.
    Bob
    3PSI gauge
  • ZmanZman Member Posts: 3,196
    Buck up
    I think you either need to give a complete description of the components and the issue you are having or buck up and do some reading.
    No one can help you if you are not specific.
    A drawing would help.
    Carl
    Albert Einstein
  • Andrew boilerAndrew boiler Member Posts: 44
    Update
    I posted having problems with my PRO Non-Programmable Digital Thermostat (1 Heat
    I have my own zone in my master bed room and it's saying it's 71 in my room it's set at 68.
    Is there anything I can do to save service man to come on a Sunday?
    Wire
    What is the other end of the wire attached too?
    Do you have and know how to use a multimeter?
    Carl
    Albert Einstein
    Wire
    No I don't know how to use a multimeter
    What happened
    When did it stop working?
    Is this a new t-stat?
    The wire goes to your mechanical room. Can you post a picture?
    Carl
    Albert Einstein
  • WeezboWeezbo Member Posts: 6,232
    over shoot...
    it may just be that the boiller fired off and it ran the heat into the room and it is now there trying to get out the emitter as quick as it can , if you are in an apartment buildingg most likely you are thinking to open a window ...dont. it is probably not your thermostat per se.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
