How Thermostat works
Andrew boiler
Member Posts: 44
How does a thermostat works if I have it at 68 will it come on when it's below 68?
I have a Honywell thermostat no idea hot to check it I need help
On and off
is all a conventional thermostat can manage. Look for a setting called swing, which determines how far above and below the setpoint the stat will wait before it turns on or off.0 -
More info would be helpful...
What is the t-stat doing now???
What is the model number of the t-stat?
By knowing these things we can help you possibly fine tune the t-stat to work more like you want it to...0 -
How thermostat
My thermostat is a Honeywell TH1100D1001
Don't know that much about it0 -
+/-1
That is what your t-stat is supposed to hold.It may take a few days to get there.
You also may be able to change the cycles setting. Check the attached installation manual for instructions for doing that.
http://s3.pexsupply.com/product_files/TH1100D,TH1110D,TH1210D,TH2110D,TH2210DInstall4.pdf0 -
Where did you find the +/-1 deg spec?
Honeywell's manual and website do not specify the swing and electronic thermostats can vary from +/-0.5 to +/- 2 degrees.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
