nest thermostat
is the Nest thermostat will work with just one zone?
  • Zman
    Zman Member Posts: 7,561
    Switch
    Yes , the nest will work with a single zone system.
    Most thermostats are simple switches. When the temp gets to the set temp they close the circuit. The nest is supposed to track your habits and adjust automatically. It is still just closing a circuit nothing else.
    Carol Fey has some great books on controls in the Heating Help Store.
    Carl
    Albert Einstein
  • Timco
    Timco Member Posts: 3,040
    Nest
    It's not always compatible. Will not just hook to a Triangle. Had to install a relay and transformer to get constant voltage.
