Thermostat Wiring
Member Posts: 4,013
For heating, we always connect wires to RH and W to call for heat. Until now, I never realized that if you connect a neutral wire from the transformer to terminal C on the thermostat, it will power the thermostat and you don't need to change the batteries.
Most of you will say "Duh", but I just never knew that.
Only if
you have that 3rd wire . Around here no one runs that extra wire ! And a big callback problem is dead batteries ........0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
