Old Base Board
superdave
Member Posts: 155
I have a building that was built in 1965. The Fin tube is 1" copper size 4 1/4" X 2 3/4" and 48 fins per foot. The GPM is unknown and water temp is 180F. What do you think the BTUs per foot would be. Each Unit is about 650' - 750' and there is only 12' - 14' of base board per unit.
Thanks for your time.
I checked the Hydronic Rating Handbook.
They're not showing it. How about doing a heat-loss calculation?Retired and loving it.0 -
55 plus living
I am going to look at it my self to see if size of base board is correct. I will also get a room lay out. I forgot to say this building is 55 and older. The turn the heat on Sept. 15 so the heating side of thing is very critical.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
