Thermostat Question
Junkbox
Member Posts: 7
I replaced my old thermo stat with a new Honeywell RTH2510 Programmable thermostat. My problem is the old one only had 2 wires a White and Blue.
My new one does not have a digram for a 2 wire set up. It give me
B O G Y W/Aux R Rc I am lost as what to do any help would be great
See page 6
of these instructions:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2421ES.pdf
I believe that you want to connect your two wires to "R" and "W/Aux".8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Also...
You'll have to follow the installer setup section to configure the thermostat to match the type of system you have.
You may want to call their tech support line for assistance.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
