primary/secondary
Paul S_3
Paul S_3 Member Posts: 1,288
When using a regular atmospheric hot water boiler with primary/secondary piping....how do I control the primary pump? System is going to have four high temp baseboard zones.....and three radiant zones with 3 way mixing valves.....should that I use a relay to turn primary pump on whenever any zone call for heat or outdoor reset Paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
  • The easiest way
    is to wire it off the boiler if it has a pump relay.
    If not, create you're own pump relay off the end switches as you say.
  • Paul S_3
    primary/secondary
    Do you recommend one pipe primary secondary or two pipe on a residential home? Heat loss of home about 160000btuh's...thanks Paul s
    347-692-4777
    ASMHVACNYC.COM
