Poor Mans Insulation
ALIGA
Member Posts: 194
started the boiler room insulation with r30 fiberglass and duct tape.
before:
after
before:
after
Please note
The Kraft paper on that is not fire rated and poses a risk of spreading fire. Also note compressed insulation has very low R rating.Cost is what you spend , value is what you get.
cell # 413-841-6726
thank you Charlie
kraft paper has been removed, replaced with foil tape.0 -
Compressed
But do you still have R30 compressed down to something like R5?
In order for R30 to be R30 it must be its full expanded thickness.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Give me a flippin break.
Why don't you just use the proper stuff.gwgillplumbingandheating.com
What's wrong
I have read people doing the same on the forums. Plus I had extra batting laying around.
It is a pain to wrap. I have about 40 feet if mains to cover, I will go ahead and order the pipe insulation in 1 inch.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
