radiant heat loss calculation?
Paul S_3
Member Posts: 1,261
Hey everyone....when doing a heat loss calculation on a home that will be using radiant heating (staple up job) can I use a regular heat loss calculation that I would use on a baseboard job for example Slant Fins heat loss express? Or is there another calculation specifically for radiant heating thank you Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Yes
Heat loss calc only calculates the amount of heat needed(or heat lost) to warm a room/building. It doesn't matter what system you tend to use in your house as it doesn't take any of that into consideration.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
