Siggy in DC
Dan Foley
Member Posts: 1,258
ACCA - National Capital Chapter is hosting a John Siegenthaler seminar on October 3. The title of the seminar is The Latest Trends and Technology for Hydronic Heating and Cooling. The seminar is sponsored by Triangle Tube and will be held at Thos Somerville Co. Chantilly branch. A flyer is attached.
Course Description:
A one-day course, taught by an expert in the field:
Hydraulic Separation
beyond primary / secondary pumping
shows how to achieve all the benefits of primary / secondary piping, with simpler, low cost approaches
Distribution efficiency & low power pumping
this topic proves that, and shows ways to significantly lower the parasitic operating cost of hyrdonics, especially in comparison to forces air heat delivery
Air-to water heat pumps
discuss how to operate and shows several ways to connect them with contemporary hydronic distribution systems
Small scaled chilled water cooling
you will learn several novel approaches using the latest hydronic design techniques and hardware options
Low mass/low temperature distribution systems
examples of hydronic heating meeting the needs of low energy use buildings
Instantaneous DHW using renewables + electricity
the methods discussed produce heated water faster than gas-fired tankless heaters, and are simple to install and maintain.
Hope to see you there!
- DF
Course Description:
- DF
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
