unitrane fan coils
md
Member Posts: 24
can anyone help me find the btu output for a trane fan coil,,,,,,, the unit is 4 pipe 2 for heating 2 for cooling the tag says unitrane fan coil air conditioner,,, model b12aL06 serial number s78f09545. WE tried to email trane but we got a run around, they were installed about 1978 vintage,,,,thank you..
Heating side
If you have nothing else to go on, many of those where designed for 4fps flow and a 20 degree delta t.
If you have a 1" supply that would be 8gpm x 20x500 = 80,000 BTU.
There is a chart in the "conversion factors" tab on the top of the page.
It is only a rough estimate but it's better than nothing.
Albert Einstein0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
