To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
indirect or direct electric resistance
HillyHilly Member Posts: 333
I need to replace an oil boiler w/ tankless coil. The customer is very set on going with an electric wall hung boiler for the setup, likely a Slant/Fin. Is an indirect more efficient than an electric hot water tank? His new boiler will be off electricity anyway so in short the questions is does he add another breaker to the panel and put in electric HWT or use an electric indirect?
  • SWEISWEI Member Posts: 7,356
    If they have the service capacity
    I'd install a tankless electric water hearer or three.  Depending on the house layout and size, two or three smaller units can frequently work better than one big one.  You can also squeeze them into a smaller (electrically speaking ) service.  They will occupy 2-4 breaker spaces each (six for the big ones.)  I've had good luck with Stiebel Eltron (and the company seems to be here for the long run, unlike a few others we've seen.)
  • Larry WeingartenLarry Weingarten Member Posts: 1,101
    Would a heat pump...
    ... work for the DHW load?
    Yours,  Larry
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
