Mod Con Boiler Safety Switch Requirements-
ced48
Member Posts: 469
Does the NEC, or others, require a safety switch, and where must it be placed. The boiler has it'e own toggle switch, but it's not really visible, and certainly not a safety shut off device.
Looks Like No,
but what about Rhode Island?0 -
NEC Article 422
requires a disconnecting means within sight of the boiler. If the fan or pump is not over 300 VA or 1/8 HP, the panel breaker can be used as the disconnect. If the panel is not visible, a single pole switch is usually the least expensive solution that qualifies.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
