To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
steam oil to gas conversion
PaulPaul Member Posts: 244
how much will you save converting a modern oil steam boiler to a gas steam boiler approx. oil in mass is double the cost of gas. thx
  • Jamie HallJamie Hall Member Posts: 6,058
    If it's really a modern oil boiler
    the efficiency is pretty good already; you may have slightly better efficiency on gas, but your savings will come from the difference in the price of the fuel, not from replacing the boiler.  Which is considerable.
    Some boilers can be converted from oil fired to gas fired (not all); you might look into that first.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • BobCBobC Member Posts: 4,245
    How is it sized?
    If the current steam setup is well matched to the heating load (EDR) the savings will be the difference in fuel costs, last year oil was running about $3.50 and NG in the Boston area was about $2.20 for the equivalent amount of gas (1.4 therms). We won't know what the cost is till the gas company posts this years winter rates that take effect at the end of October.
    If that steam boiler is oversized you can dial the output down to match the load by drilling the correct orifice size for the input BTU you need and that can save some fuel.
    Bob
    3PSI gauge
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
