To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Slow leak at joint (picture)
BQ1001BQ1001 Member Posts: 1
Slow drip (every 2-3 min). Should I have the whole thing cut out and replaced.
Left pipe is main, Rt to single outside spigot, middle to house.
Any advice appreciated.
  • jonny88jonny88 Member Posts: 1,139
    drip
    easiest fix would be to cut left and right side.heat of bull of tee where drip is clean and reassemble with new clean fittings,good luck.remember to drain water first...
  • bob youngbob young Member Posts: 2,174
    LEAK
    CALL A LIC. PLUMBER.
  • ChrisJChrisJ Member Posts: 7,564
    edited November 2013
    Comment
    removed
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
    If you even insult my steam system in a dream, you better wake up and apologize ò¿ó
    Steam system pictures updated 1/25/15.
    https://goo.gl/photos/ZgpNUTyckkmiEdAf9
    LEAK
    So chris, you would prefer i walk a do-it-yourselfer through a repair procedure cutting out & condemning existing pipe & fittings & replacing with new & possibly  burning down his house using a torch.  no thanx. some jobs should be done by a pro. thats the way it is. i  have always given solid advice when its appropriate but i also am aware of liability issues. are you ?  at one time this was strictly a forum for professionals , that has evolved,  for better or worse. which are you,  a tradesman or a handyman ?  bob nyc lic. plbr.
  • Bob is tolally
    Bob is totally correct about calling a licensed plumber to do the job properly... there are many on this forums I won't even help due to the risks involved.
    Comment
    removed
  • RichRich Member Posts: 2,128
    Chris
    Advice was asked for and advice was given (sound advice at that) . What would possess you to make an adversarial comment about another's opinion ? Best off just giving your advice and calling it a day . Unless of course the advice given endangered the OP or his property .  Just my .02 . By the way OP , call a licensed plumber !
    You didn't get what you didn't pay for and it will never be what you thought it would .
    Langans Plumbing & Heating LLC 732-751-1560
    Serving most of New Jersey , Eastern Pa .
    Consultation , Design & Installation
    Rich McGrath 732-581-3833
    Perhaps
    you're right Rich.
    I was just surprised to see such a post on this forum. Maybe I need to venture out of the steam area more often.
    Bob, please accept my apologies.
    COPPER REPAIR
    Chris, apology accepted. that was a simple i hour repair job. start to finish. shut water ,drain,cut out, repipe , solder,restore water service,test. submit invoice, go to next job.   alternate scenario for a amatuer that has not mastered pipefitting & soldering. all day torturous  job, water still off, call plumber to cut out mistakes & do job over. to each his own. if you gotta ask how to attack a little simple job like that , yeah, you should probably leave it to an expert.....if you value your property ,that is . case closed. sometimes a little bit of knowledge can be a dangerous thing. i respect my craft very seriously.
  • TalldutchTalldutch Member Posts: 4
    slow leak
    I would advise a licensed plumber for this    the ability to solder in tight quarters is something that is learned   an older home can go up in smoke very easily and embers can last for hours before they ignite
  • icesailoricesailor Member Posts: 7,265
    Leaks:
    Whomever installed those fittings in the first place was a hackaroo. If they had held the pipe riser or squeezed the tube, it wouldn't have moved. If the joints had been wiped with a rag, the installer would have known that the fitting either wasn't soldered properly of it moved. More likely, it wasn't completely heated enough for a proper solder job.
    The Hackaroo probably heated the joints from the "tee" and then did the St. 90 last. Using a rag would have shown that the last fitting to be soldered, the bottom of the Street Ell wouldn't be hot.  Or, if it moves. A leak. When you pull it apart, if the end of the tube isn't completely soldered, it wasn't hot enough. If it is completely soldered but part of the solder is a dull grey, it moved.
    So many "plumbers" today use a Bernzomatic Blow Torch that burns the wall 12" away. A Air/Acetylene "Prestolite" type with a #3 tip always gets the fitting just right and you can reach behind it with the tip of the flame. I always am extra careful when I use my Blow Torch because it is so hard to feel when the back side of the fittings that you can't reach.
    And pasting both the pipe and fittings goes a long way. It almost looks like it leaked and someone red" the pipe to stop the leak.
    Seen that before. There's the right way. And the "other" way.
    LEAK
    Sailorman, in the time it took for you to explain the ins & outs of sweating joints, i could have repiped the whole house. plumbing should actually done by plumbers . its not a hobby .the p[lumber protects the health of the nation. this a fact.
    Depends
    A licensed plumber almost killed me and my family after telling me our boiler was properly serviced and venting properly. Luckily we have multiple CO detectors and when they all go off you know its not a false alarm.
    Since then I have done all of my own work, with the appropriate permits and inspections by the town of course. I also own my own manometer now as well.
    icesailor is a good man and often gives good advise and personally I always welcome his opinion.
  • your licensed plumber
    Wasn't a boiler man to begins with...
  • billbill Member Posts: 429
    The way I see it is...
    With a thread that's 7 weeks old and the original guy hasn't been heard from, it's fixed:) But the drama continues.
    Oh yes
    He most certainly was. He is a licensed plumbing and heating contractor.
    In fact he claimed he specialized in steam heat and oil burner service.
    I'm done with this thread, as Bill said its dead and the drama should end as well.
    I wish all the best and happy holidays.
  • SWEISWEI Member Posts: 7,356
    Licensed or not
    is a discussion worth having here IF we all agree to follow Rule #1.
    Perhaps a new thread might be in order?
    Piping:
    I've been a Licensed Massachusetts Journeyman Plumber since 1976 and a Licensed Massachusetts Master Plumber since 1974. I've soldered more than one pipe before.
    What I wrote obviously wasn't for an experienced piper like you. It's for someone that might like a pointer or two.
    My old Boss had a thing about Street fittings. They cost more than an ell. Only use a Street Ell when there was no other way. Plan your piping around not using them. Later I figured out (through experience) that there was another reason. It was easy to overheat and/or under heat a Street fitting and get a leak where that one is leaking.
    Be careful making empirical statements about how fast you can pipe something. You might find out that you can't do something as fast as you think.
  • JohnNYJohnNY Member Posts: 1,776
    Elbows
    There's no tee in that picture, for what it's worth.
    For private consulting services, find John "JohnNY" Cataneo here at :
    "72°F, LLC"
    For a quick reply you can also email John at John@72fLLC.com
    Please note that 72°f, LLC is not limited to the boundaries of the service area adhered to by his larger company, Gateway Plumbing & Heating, and John travels regularly to out-of-state clients for consulting work.
    tee?
    Looked like a 3/4 x 3/4 x 1/2 tee with a 3/4" street ell into it to me.
  • billtwocasebilltwocase Member Posts: 2,385
    Chris is right
    Tee with either a street 90, or a very short piece of pipe and a 90
    Tee's
    We're all right that it is a tee.
    Closer look might show it to be a 1" X 1" X 3/4" tee though. 1/2: has a much higher neck down.
    If it's a 1" soldered tee though, it takes a little more finesse for the rookies to solder them properly.
    A rag to wipe the grapes and snots off the soldered fitting will go a long way to tell you if you got it hot enough and looks right spiffy when done.
    The way I see it is this...
    I think we all should fly into this guys town, be picked up, and go over and fix it. All expense paid :) Of course RFB!
  • ZmanZman Member Posts: 3,168
    Umm...
    This guy is a "one post wonder" from 2 1/2 months ago
    This problem was solved months ago with some sharkbites and a scrap piece of garden hose.
    Maybe you guys should debate something more productive.
    How about cheerios vs corn flakes?
    Carl
    Albert Einstein
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
