fuel filter arrangement
steampunk_2
Member Posts: 28
in Oil Heating
I;m running the fuel supply line to the beckett gun on the mst-288 I installed in my house. the tank is about level with the pump and about 8 feet away. the becket manual says to install a 50 micron at the tank and a 10 near the gun. garber, so far as I know, doesn't make a 50. can I use a garber "m" 35 micron filter at the tank and an r-2000 near the gun-or- should I put the r-2000 at the tank to catch the water and the "m" with the gauge at the gun? how should I set this up?
thanks to all
thanks to all
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
