Air compressors
Jack
Jack Member Posts: 1,047
Kinda sorta off topic, but thought I'd ask. I've got a substantial structural steel project here at the house and all my compressor filtration gear got lost in the move west. What do you use to filter and dry your compressed air? I don't want to pump a bunch of moisture into my plasma cutter. Thanks for the help
    hot_rod Member Posts: 22,022
    depends on
    how much air you compress and the humidity. Here in Missouri I tried those throw away plastic moisture traps. But if I use the plasma for 20 minutes or more the filter is saturated.
    I see the pros use a quality refrigerated moisture removal system. I just bought a nice airbrush so I need to upgrade my moisture removal system. I guess you get what you pay for. For as much as I use mine I may just up-grade to a larger capacity inline trap.
  • RJ_4
    RJ_4 Member Posts: 484
    Air
    I would use what we used for years for pneumatic controls,  Use a inline modular filter system, first a dirt filter than a oil filter (available at Graingers),  Than a refrigerated air dryer, also a auto or manual blowdown for the air compressor tank.
    RJ
  • SWEI
    SWEI Member Posts: 7,356
    edited September 2013
    We've used these for years
    with good results http://www.motorguardplasma.com/2plasma.html
