Prestige excellence water piping with recirc
TLM
Member Posts: 38
Im trying to make heads or tails of their piping schematic. I am in MA and have a second diptube as per mfg instruct. I don't understand why I cant bring the recirc line back to that connection instaed of using what they show as a "cross" in the CW line. Any thoughts would be appreciated Have done plenty of solo.s w indirects.
Recirc
The idea is that the water does not want to be forced through the indirect tank.If it is, it defeats the mixing valve. The returning water should have an equal opportunity to go through the hot or cold side of the mixer, depending on the position of the valve. Some of the water may go through the tank in order to raise the temp a bit, some may bipass through the cold side. Keep in mind that during recirc, there is no flow from the domestic cold. It has to use the same recirculating water.
An easier way to pipe it is to use mixer with a recirc port. The Honeywell AM series works well.
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
